Thanks,
Gus
After the cooling-system repairs, check the heater core for a blockage that prevents hot coolant from circulating and producing cabin heat. Replace the heater core if it is restricted.
A 1994 Chevrolet Cavalier originally had no heat. After a thermostat replacement, the gauge climbed to 260 degrees while the hoses stayed cool and the heater blew cold air. The radiator cap and coolant-temperature sensor were replaced, then a lower hose failed. Further inspection found a warped head, a badly rusted radiator, and a water pump with rusted-off impellers. The owner replaced the radiator, water pump, hoses, fan, and relay, and had the head serviced. The engine then stayed in a warm range but the temperature swung between about 140 and 200 degrees, and there was still no heat. The final suggestion was a blocked heater core.
