1991 Chevrolet Cavalier No Heat
CHEVROLET
WETBER360
I have a 1991 CHev. Cavalier RS. The car is reaching normal operating temp. but there is no heat from the heater. How do you check to see if the coolant is flowing through the heater core?
Nov 29, 2006 at 4:32 AM
BACKYARDMECHANIC
  • 337 POSTS
First check to see if the coolant is reaching the heater by removing both heater hose that go to the heater core. One hose feeds the heater core the other is the return, similar to a hot water heating system used in a house. You should have coolant in both. Next with the hoses removed try to run water through the heater core with a garden hose. If the water flows freely and coolant is present in the hoses, I would then check the the valve that controls the flow to the heater core to see if it is working properly. Good luck Backyardmechanic
Nov 29, 2006 at 7:45 AM
Suggested Repair
Remove both heater hoses and confirm coolant is present in the feed and return. With the hoses off, flush the heater core with a garden hose to see if water flows freely. If coolant is present and the core flows freely, check that the heater control valve is operating properly.
Conversation Summary
The owner of a 1991 Chevrolet Cavalier RS says the engine reaches normal temperature but the heater produces no heat, and asks how to check coolant flow through the heater core. The expert advises removing both heater hoses to confirm coolant is present, flushing the core with a garden hose, and checking the heater control valve if flow is free.
