Problems on monte carlo
JDCMJC
2001 chevy monte carlo has 52,000 miles on it and has a 3.8 engine. The radio locks up and the dimmer switch light doesn't light. The amp meter doesn't always work. The air conditioner does not work when this happens.
Apr 20, 2007 at 3:17 PM
GARFIELD
  • 197 POSTS
It sounds like you have a loose ground somewhere in your dash. If you have a manual for your car with an electrical schematic then look at all the problem areas and follow the ground wires back, bet they will all have a common point that they use for a ground. When you find that area is will normally be either loose connection or a dirty or corroded connection. Most automotive intermittent electrical problems can be traced down to either a loose or corroded connection. Hope this helps
Later
Gary
Apr 21, 2007 at 2:53 AM
