1997 Chevy Monte Carlo
NICE CAT
  • 1997 CHEVROLET MONTE CARLO
  • 6 CYL
  • 117,000 MILES
Egr valuve replaced car stats up drives for 7 min. Then engine stops does not restart for 30 min
Friday, April 16th, 2010 AT 6:15 PM
Do below to determine whether it's fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, April 16th, 2010 AT 6:55 PM
Related Engine Not Running Content
