1997 Chevy Monte Carlo Problems Starting the Car
JMDAVIS
  • 1997 CHEVROLET MONTE CARLO
  • 6 CYL
  • FWD
  • 97,500 MILES
Hello, we have a '97 Chev Monte Carlo which has intermittent starting problems. Every so often when attempting to start the car, the car won't start - it's just completely dead. If you wait a few minutes and try again, it starts with no problem. There is a chip in the ignition key for this particular vehicle. We've had the car in to two different shops and no one can figure out the problem. I don't believe the car had a factory installed theft system, but one has since been installed. HOWEVER, this starting problem was present befoe that system was installed, so I'm not sure if the problem ties into that or not. Any ideas? It's a great car with no other problems so we'd like to get this fixed so we can drive the car without worrying about the car starting!
Thursday, October 22nd, 2009 AT 9:20 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is there power to dash gagues, radio, ect? If yes then need to determine if ignition, theft or starter solenoid. Next time it does no start jack up get to starter put test light on IGN solenoid wire turn key does it light? If yes then dead spot in solenoid.
Let me know
Thanks for donate
Thursday, October 22nd, 2009 AT 10:22 AM
