1995 Chevy Monte Carlo my car won't start
ANGELANICOLE20
  • 1995 CHEVROLET MONTE CARLO
  • 6 CYL
  • AWD
  • 158,000 MILES
A couple weeks ago it started to not star it tok acouple times for it to go. Them one day it just gave out we took the starter out and had it tested but if ran fine the lights work the radio work but it won't start.
Monday, June 23rd, 2008 AT 2:26 PM
Do you have a check engine light On prior to this problem?
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start then get back.
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Monday, June 23rd, 2008 AT 2:31 PM
