I replaced the fuel pump the car now has fuel pressure and spark the car tries to but will not start.
Wednesday, December 10th, 2008 AT 6:11 PM
MECHANIC
Check the actual fuel pressure with a fuel pressure tester designed for your system if okay might want to check for injection pulses at the injector/s harness conenctor with a noid lite. No injection pulses you won't get fuel to the cylinders.
