The car will start and run fine for 10-15 miles then all the lights start going dim and the speedometer and tach will move way up and down then the car will stall
if you try to start it all you get is a clicking sound. 2-3 hours later it will start right back up. The alternator is charging and I installed a new battery
SPONSORED LINKS
Saturday, April 12th, 2008 AT 1:51 PM
MIKE H R
MECHANIC
With the light dimming as you drive the car shows that there is a regulator or altinator problem. Check the belts for tension. You can take it to a store like auto zone and have the altinator checked, they can also check the drain of the battery. When you let it sit for a couple of hours the battery will recharge some but will not do it for long unless properly charged. The speedometer and tach are electically controlled and will fluxuate when the voltage starts to get low. Check all the electrical connections at the battery to make sure they are clean and make good connections.
