1995 Chevy Monte Carlo
JOHNJR11591
  • 1995 CHEVROLET MONTE CARLO
Engine Mechanical problem
1995 Chevy Monte Carlo 6 cyl Automatic
wont start like it should takes a few minits makes a funny noies and when it gets jumped starts right up
it wont want to drive for long distancis
Friday, April 9th, 2010 AT 9:43 AM
INTERNETMECHANIC
  • 700 POSTS
How long since a tune-up? Use a gage and check fuel pressure. Any applicable trouble codes? With extended crank, have helper crank while you visually check for spark at the plugs, if you have spark, check fuel pressure. Make sure the battery has a full charge and the connections are good.
Friday, April 9th, 2010 AT 10:14 AM
