Put new timing chain and gear, still will not do a thing, will turn over, will not fire or start
Thursday, July 3rd, 2008 AT 11:10 PM
BLACKOP555
MECHANIC
You can try to dump some gas in the throttle body and try to start it, if it firesup more then likely you have a fuel issue and you should be checking out the fuel pressure and injectors.
If no start suspect a issue with spark. Procede to buy and use a spark tester and check for spark on all cylinders and at the coil.
