1993 Chevy Lumina Car will not start.
BEACON
  • 1993 CHEVROLET LUMINA
1993 Chevy Lumina 6 cyl Two Wheel Drive Automatic
the engine cranks but will not turn over. Checked teh fuel pump and the noise it's supposed to make is there.
my mechanic (who is a pretty good one) is no longer having in this area, so thats out of the question. He gave me a few tests to run that I still have to run. I have to run a spark test to see if there is a spark. Also there is a "smell" test to see if the fuel is being burnt or not.
i am trying to find a diagnostics flow chart to go off of- i.E, check this. If it works/does not work check (accordingly) this or that. Then if if this works or does nto work, check this or that.
does anyone know where I can access something like this, or even give me a basic rundown? My mechanic is stuck putting an engine into a truck today so he doesn't really have time for tech support right now. Any help will be greatly appreciated.
Friday, August 21st, 2009 AT 3:30 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Friday, August 21st, 2009 AT 3:36 PM
