2002 Chevrolet Cavalier Gauges Not Working
OUTNABOUT
We have a 2002 Chevy Cavalier 2.2L with 75,0000.
A few weeks ago the battery died on us. We put a new battery in with a boost. Now none of the gauges are working. Please help. We have checked all fuses they seem to be fine. Not sure the book states we might have to reset it manually, but it does not tell you how. Can you help?
Thanking you in Advance :?
Jun 25, 2007 at 5:26 AM
E40WATER12
  • 522 POSTS
When hooking up the new battery are u getting any power? any lights? I would try and disconnect the neg post of the battery let it sit for 5-10 mins then connect it back together see what happens. If the same thing happens, Think recheck youre fuse panel for youre cluster fuse, Or u may need a new ECU computer for youre car, Better getting one from the wrecker's.
Good Luck.
Jun 25, 2007 at 7:25 AM
Suggested Repair
Confirm the car has power and lights. Disconnect the negative battery cable for 5-10 minutes, then reconnect it. Recheck the instrument cluster fuse; if the gauges still do not work, the ECU may need replacement, preferably with a used unit from a salvage yard.
Conversation Summary
After a dead battery was replaced on a 2002 Chevrolet Cavalier, none of the gauges worked, although the fuses appeared fine. The expert advised confirming power and lights, disconnecting the negative battery terminal for 5-10 minutes, rechecking the cluster fuse, and considering a replacement ECU from a salvage yard if the problem continues.
