1993-94 Chevy Cavalier Fan Not Working
BIGCAT42
i have a 1993-94 chevy cavalier Z24 and my fan is not working can you tell me what is wrong?
Jul 15, 2007 at 1:32 AM
E40WATER12
  • 522 POSTS
Have you checked youre fan fuse?. Also have u tryed running live power wire from the battery to the fans power wire directly, If it doesnt kick on, Then I would say youre fan is burnt out, Also if it does work, youre fan relay is burnt out.
Jul 16, 2007 at 9:34 PM
Suggested Repair
Check the fan fuse, then apply battery power directly to the fan power wire. If the fan does not run, replace the fan motor; if it does, replace the fan relay.
Conversation Summary
The owner of a 1993-94 Chevrolet Cavalier Z24 reports that the fan is not working. The expert advises checking the fan fuse and applying battery power directly to the fan. If the fan does not run, the fan motor is burned out; if it runs, the fan relay is burned out.
