1998 Chevrolet Cavalier Fan Won't Run
CHRISSYLEW
i own a 1998 chevy cavalier z24 2 door 2.4 liter and it keeps leaking antifreeze. we fixed the problem after 5 attempts but now my fan doesnt kick on when its suppose to, or at all for that matter. i lost my drivers manual and i dont know where the fuses for the fan are so i dont know if that is the problem.... will i need to get a new fan or what?
Jun 21, 2007 at 7:45 AM
E40WATER12
  • 522 POSTS
If you look in youre engine compartment, On youre drivers side of the car, U will see a black color plastic panel, It contains fuses and relays, I would check out youre fan relay fuse, Could need replacing, Also Also u might want to use a piece of speaker wire, Run a jumper wire from the positive terminal to youre cars cooling fan, See if it turns on, If not youre cooling fan is no good, Also if youre fan turns on, Then youre fan relay switch is not good.
Good Luck.
Jun 21, 2007 at 8:14 AM
Suggested Repair
Check the black fuse and relay panel on the driver's side of the engine compartment, especially the cooling fan relay and fuse. Jump power from the battery positive terminal to the cooling fan. If the fan does not run, replace the fan; if it does run, replace the fan relay.
Conversation Summary
The owner of a 1998 Chevrolet Cavalier Z24 said the cooling fan no longer comes on after an antifreeze leak was repaired and asked about the fan fuses. The expert advised checking the underhood fuse and relay panel on the driver's side, jumping the fan from the battery positive terminal, and replacing the fan if it does not run or the relay if it does.
