2000 Chevrolet Cavalier Temp Gauge
SENTRAMAN
  • 13 POSTS
Hi
My engine temperature gauge is around 100 deg when i'm stuck in the traffic for a long time but when i'm on open road it's just below 90. I'm thinking my thermostat opens at 98 deg, so i want to put one that has lower temperature rating. If i do this will it affect the performance of the car or in other words is this a safe to do. Also i checked the level of my antifreeze it seems to be fine. Thanks for the help in advance.
May 3, 2006 at 8:28 AM
LOSONE
  • 1,616 POSTS
Your engine is designed to run about 100C or 212 F. Do not change the T-stat your engine performance and emissions will drop. A T-stat controls the minimum operating temperature of an engine.
May 3, 2006 at 8:37 AM
Suggested Repair
Do not install a lower-temperature thermostat. The engine is designed to run about 100°C (212°F); a cooler thermostat can reduce performance and emissions. The thermostat only controls minimum operating temperature, and the reported readings are normal.
Conversation Summary
The owner of a 2000 Chevrolet Cavalier reports a temperature gauge around 100 degrees in traffic and just below 90 on the open road, and asks whether a lower-temperature thermostat is safe. The expert says the engine is designed to run about 100°C (212°F) and advises against changing the thermostat because performance and emissions would drop.
