1994 Chevy Cavalier No Codes
RCALZADILLA
  • 10 POSTS
Ref: 1994 Chevy Cavalier 2.2L, L4, VinCode 4, "J"Carline,MFI. 63,000 miles, for real.
Check Engine Light is on but, cannot retrieve codes.
Have Chilton Manual which instructs, at the Data Link Connector (12 connector), ground terminal A to terminal B(ground).
My underdash DLC has no letters on it but by referring to wiring diagram the Pink lead comes from the ECM. Have tried connecting it to ground and to an engnine ground without success.
Engine idles high rpm even when warm.
tks
raul :mrgreen:
Jul 17, 2007 at 7:02 AM
2CARPRO JACK
  • 11,533 POSTS
If i remember correctly A and B are the top left terminal,and the one to its right, use a jumper wire to connect the two together , then turn key on and start counting the flashes
Jul 17, 2007 at 7:19 AM
RCALZADILLA
  • 10 POSTS
No connector at B.
I found an image of the connector which has the following 12 pin order when faced from the front:
TOP ROW: F E D C B A
LOWER " : G H - - - M
My Cavalier have only four conductors at the following locations
F (Pink) A(Brown/Black)
G(Black/Wjote H(White/Black)
Tried connector each to a good round and still does not work. Tried Pink to the other and ground: nothing.
If any ideas, would be welcome.
tks
raul
Jul 17, 2007 at 7:50 AM
2CARPRO JACK
  • 11,533 POSTS
According to my software, if there is no wire at terminal B then a hand-held scanner must be used to retrieve codes
Jul 17, 2007 at 8:51 AM
Suggested Repair
If the data link connector has no wire at terminal B, codes cannot be retrieved by jumping terminals. Use a hand-held scanner to read the diagnostic trouble codes.
Conversation Summary
The owner of a 1994 Chevrolet Cavalier has a check engine light on but cannot retrieve codes by grounding the data link connector as the manual describes. The connector has no wire at terminal B. The expert states that a hand-held scanner must be used to retrieve codes in that case. A high idle when warm was also reported but not diagnosed.
