1985 Chevy Cavalier Code 22 TPS
85CAV
1985 Chevy Cavalier 200k+ miles engine code "P" 2.0L ohv with model 300 tbi. my question is this, what would cause a trouble code of 22 (low voltage at the TPS). i took my car to the carwash and cleaned the engine compartment for the next step in my upgrade/repair process. afterwards it started running rough, figured something got wet, and drove it for a few days. looked for wet components, and checked all vacume / electrical connections i could find. "check engine" light comes on intermittantly and has a trouble code stored as code 22.would an 02 sensor cause this? what do you think would cause this?
Mar 5, 2007 at 7:29 PM
CHEVY22
  • 1,375 POSTS
hi
if the tps is fauly this could cause the code , if you have a test light check the hot side and see if you have 5 volts wide open throttle , if the feed is good most likely the tps is bad
Jim
Mar 13, 2007 at 7:50 AM
Suggested Repair
Check the TPS 5-volt feed at wide-open throttle with a test light. If the feed is good, replace the faulty TPS.
Conversation Summary
A 1985 Chevy Cavalier with a 2.0L TBI engine began running rough and intermittently showing a check-engine light with code 22 (low TPS voltage) after the engine compartment was washed. The owner asked whether an oxygen sensor could cause it. The expert said a faulty TPS can set the code and advised checking the hot side for 5 volts at wide-open throttle; if the feed is good, the TPS is most likely bad.
