2001 Chevy Cavalier Park Rev Limit
HORTENCIA613
while i have my 2001 chevy cavalier on park I rev the engine and the rpm does not go over 3000 rpm when it hits 4000 it goes back and forth between 3000 and 4000 as if wants to turn off I replaced the throttle position sensor because the computer said that was the problem but it still continues to do the same thing
Feb 27, 2007 at 9:57 AM
CHEVY22
  • 1,375 POSTS
there is no problem , this is a safeguard , its called a rev limiter , while in park or neutral the engine will not exceed 3000k rpm it cuts out two cylinders , its made that way , thats why its that way so people dont over rev them
jim
Feb 27, 2007 at 11:59 AM
Suggested Repair
No repair is needed. In park or neutral the engine uses a rev limiter that holds rpm near 3000 and may cut two cylinders so it cannot be over-revved. Replacing the throttle position sensor will not change this normal safeguard.
Conversation Summary
The owner of a 2001 Chevy Cavalier said the engine would not stay above about 3000 rpm in park and surged between 3000 and 4000 as if it wanted to stall. A throttle position sensor had already been replaced after a computer code. The expert explained this is normal rev-limiter behavior in park or neutral, which cuts out two cylinders to prevent over-revving.
