2004 Chevrolet Cavalier P0141
FREDNJESS
I've got a 2004 Cavalier 2.2 L with a P0141 code. I know it's the oxygen sensor, but want to make sure that I'm looking in the right place. It should be on the exhaust header, inside the engine bay, right?
Also, I just had it in the Chevy dealership to replace the ignition module, new plugs, and they fixed the fuel injectors. That was 4 days ago.
Thanks for the help,
Fred
Feb 10, 2007 at 12:17 PM
CHEVY22
  • 1,375 POSTS
HEY THERE , IF YOU JUST HAD INJECTOR WORK AND A TUNE UP I WOULD RESET THE PCM BEFORE CONDEMNING THE 02 ,THE WORK PERFORMED MAY HAVE CAUSED THIS CONDITION ESPECIALLY IF YOU HAD A FUEL INJECTOR SERVICE DONE,IF YOU DONT HAVE A TOOL TO RESET THE COMPUTER YOU CAN PULL THE NEGATIVE CABLE OFF FOR 15 MIN
JIM
Feb 15, 2007 at 6:17 AM
Suggested Repair
Reset the PCM before replacing the oxygen sensor. Recent injector service and tune-up work may have set P0141. If no scan tool is available, disconnect the negative battery cable for about 15 minutes.
Conversation Summary
The owner of a 2004 Chevrolet Cavalier 2.2L has a P0141 code and asks whether the oxygen sensor is on the exhaust manifold in the engine bay. Recent dealer work included an ignition module, plugs, and fuel injectors. The expert advises resetting the PCM before condemning the oxygen sensor, because the injector service and tune-up may have caused the code, and suggests disconnecting the negative battery cable for 15 minutes if no reset tool is available.
