1995 cavalier 140.000km . Any one knows the size,or distance.?
Thanks
Thanks
Jun 25, 2007 at 4:45 AM
Set the spark plug gap to 0.060 inch for the 2.2L (1998 and older) and 2.4L (1995-1997) engines. If idle remains erratic, also check for weak coil packs.
The owner of a 1995 Chevrolet Cavalier with about 140,000 km asked for the correct spark plug gap. The expert said the gap is 0.060 inch for both the 2.2L four-cylinder (1998 and older) and the 2.4L (1995-1997). The owner planned to try that gap to address erratic running. The expert also noted that weak coil packs can cause unstable idle.
