A code P0401 most likely means one or more of the following has happened
There is a blockage in the EGR (tube), most likely carbon buildup
The EGR valve is faulty
The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions
In fixing this code, it is quite common for people to just replace the EGR valve only to have the OBD code return. The EGR valve is not always the culprit.
Use a vacuum pump and pull the EGR valve open while monitoring engine RPM's, There should be a noticeable difference in RPM's with the EGR open
Clean out the EGR valve and/or tubing to remove deposits
SPONSORED LINKS
Monday, February 27th, 2017 AT 10:52 AM
(Merged)
