98 chevy cavalier ignition problem
1998 CHEVROLET TRUCK
EMAREL76
Just replaced the head gasket, and timing chain w/gears. Before the gasket & chain replacment I was getting fire from the ignition wires, now I'm not. Checked all wiring connections, took off hte module and had it tested, looked up a wiring schematic to test the posative and negative leeds. Checked the conection to the crank sensor. I'm at a total loss on what the problem could be. Somebody please help.
Feb 10, 2007 at 7:11 AM
CHEVY22
  • 1,375 POSTS
have you checked the obvious like , a dead battery , loose connections or other connections you pulled off to do the job that didnt go back , check again i think you may have missed a couple of wires, i have been doing this stuff a long time and when i hurry i always miss one
jim
Feb 16, 2007 at 4:55 PM
COMPASS AUTO
  • 10 POSTS
A 98 Cav. has 2 crank sensors one in the side of the block between tranny & motor, the other is behind the crank pulley I would check to see if you damaged it during removal or instalation of crank pulley.
Mar 10, 2007 at 12:52 PM
