1993 Chevrolet Cavalier Spark Plug Threads Fix
BILSONXNC
  • 11 POSTS
1993 cheverolet cavalier 230.000 2.2 One of my spark plugs blew out becuase the threads were stripping when i was getting my plugs and wires changed.... I put a healia coil in it and it held for like 2 months but it wasnt put in very good cuz i did it myself? Is there a way that i could maybe put more threads in it and put a bigger spark plugs in it since the ones that are in it now will no longer fit because the thrreads are so stripped?
Feb 18, 2007 at 11:43 AM
CHEVY22
  • 1,375 POSTS
i think its time to pull the head and either have a machine shop fix it or just replace it they are faily inexpensive , oversize plug wont work and if it did it would be unsafe , if you fix it right it wont give you any more problems , also try anti seize on the plug threads of the plug when replacing them next time it will let the plugs come out easier
thansk
jim
Feb 18, 2007 at 1:28 PM
BILSONXNC
  • 11 POSTS
Ok well what should i look up so i can price a new head for it? I type in head and it brings up cylinder head, head gasket, gaskets.... I dont really know what im looking for? what parts do i need to puirchase to replace this head.?
Feb 19, 2007 at 3:12 PM
CHEVY22
  • 1,375 POSTS
you gopt it cylinder head, and you will need a top end gasket kit also
Feb 19, 2007 at 10:21 PM
MAVSCCRMNGR
If you're replacing the head or even taking it off to have a shop work it you'll have to replace the gaskets as you go. More than likely you'll get a whole slew of gaskets when you purchase the head gaskets and you should probably just replace all of them as you go. If you attempt to use the old gaskets you more than likely will do more damage. Also you will have to get new head bolts due to the fact that these models use torque to use bolts. If you try to reuse them you can end up with leaks and eventually destroying the motor.
Jan 2, 2009 at 3:41 AM
Suggested Repair
Remove the cylinder head and have a machine shop repair the stripped spark plug threads, or replace the cylinder head. Install a top-end gasket kit and new torque-to-yield head bolts; do not reuse the old gaskets or bolts. An oversize plug is not a safe fix. Use anti-seize on the plug threads when installing new plugs.
Conversation Summary
A 1993 Chevrolet Cavalier 2.2 lost a spark plug after the threads stripped during a plug and wire change. A Helicoil held briefly but was poorly installed, and the owner asked about adding threads or using a larger plug. Experts advised against an oversize plug, recommending head removal for machine-shop repair or replacement with a cylinder head, top-end gasket kit, and new head bolts, plus anti-seize on future plugs.
