1995 Chevrolet Cavalier Spark Plug Gap
MONTREEALMAN
1995 cavalier 140.000km . Any one knows the size,or distance.?
Thanks
Jun 25, 2007 at 4:45 AM
E40WATER12
  • 522 POSTS
The correct spark plug gap for:
2.2L 4 cyl engine 98-older : 0.060.
for 2.4L cyl engine 95-97 : 0.060.
GoodLuck.
Jun 25, 2007 at 7:30 AM
MONTREEALMAN
I'll try the gap size you mention any ways to see if it improves the irraticness sorry about the spelling and thanks again.
Peter
Jun 25, 2007 at 8:13 AM
E40WATER12
  • 522 POSTS
You also some have problems with weak coil packs, they cause idle to go on freaky ways as well.
Jun 25, 2007 at 7:19 PM
Suggested Repair
Set the spark plug gap to 0.060 inch for the 2.2L (1998 and older) and 2.4L (1995-1997) engines. If idle remains erratic, also check for weak coil packs.
Conversation Summary
The owner of a 1995 Chevrolet Cavalier with about 140,000 km asked for the correct spark plug gap. The expert said the gap is 0.060 inch for both the 2.2L four-cylinder (1998 and older) and the 2.4L (1995-1997). The owner planned to try that gap to address erratic running. The expert also noted that weak coil packs can cause unstable idle.
