1994 Chevy Cavalier wont start sometimes
TRHODES73
  • 1994 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 120,000 MILES
Runs fine but when it gets hot and you shut it off it it will not start until it totally cools off
Friday, May 2nd, 2008 AT 6:16 PM
BMRFIXIT
  • 19,053 POSTS
I would check the starter and battery
Sunday, May 4th, 2008 AT 7:03 AM
TRHODES73
They are less than a year old and that is the reason we changed those did not fix problem is very intermiddent and only does it when it has been driven for a while and then you kill it it wont start back for about an hour and then it may not do it again for a week
Sunday, May 4th, 2008 AT 9:27 PM
BMRFIXIT
  • 19,053 POSTS
If it doesn't crank you need to check and or replace the starter
if the starter getting to hot will not crank until it cool down
check charging system
if the alternator not keeping the battery fully charged then it will not have enough to spine the engine when hot
if crank but no starter check for spark and fuel pressure
Monday, May 5th, 2008 AT 6:36 AM
TRHODES73
It does not turn over or anything and it has 12 volts could it be the crank position sensor or the ignition module?
Monday, May 5th, 2008 AT 6:14 PM
BMRFIXIT
  • 19,053 POSTS
If it doesn't turn
I would recheck the alternator and charging system
recheck the starter
recheck the battery
when it does it try to get a jump
if start with a jump check the battery and charging system
Monday, May 5th, 2008 AT 7:26 PM
