Drive about 6 miles, hear metal noises, engine begins to lose strength, oil red warning sign is on, I turned
off engine. 30 Minutes later I tried to start it again but no luck. I checked oil, was ok, check battery, ok.
fuel, ok. checked spark... NONE. Then I changed the following parts: Ignition wire, ignition coill (2 pcs) and ignition module. Crankshaft sensor, oil pressure switch, and oil pump. After all this there is still no spark. I tried 15 secs. cranking the car but oil pressure switch is still on.
Is this the reason why the car does not function?
What would be the reason that there is not enough pressure going to the oil circulation?
Oct 17, 2009 at 2:24 AM
