wont start
FAJS42
1992 chevy caprice.v8 350 car was starting when i sprayed ether in carb.now its not getting gas and wont start.
Oct 26, 2007 at 8:14 AM
BLACKOP555
  • 10,386 POSTS
since your not getting gas the easiest thing to check is the fuel shut off switch if it is equiped in your car. if that checks out good i would follow all fuel lines to the tank checking for kinks or cracks. if all checks out good drop the fuel tank and replace the pump. if the new pump does not work suspect the fuel pump relay.
Oct 26, 2007 at 10:00 AM
