1982 Chevrolet Caprice No-Start
ICHTHUS9
I have an '82 4.4L Caprice engine in my pickup which won't start. The starter cranks well, I'm fairly certain the engine's getting gas, I've checked all the fuses, the battery's been tested and it's good, but I can't get it to turn over at all, much less start. It has sat for a few months. My best assessment for far is that it's not getting spark, but that could be wrong or if it's correct I don't know why.
Sep 17, 2007 at 6:17 AM
  • 75,988 POSTS
[quote:ebc84d9b81="Ichthus9"]I have an '82 4.4L Caprice engine in my pickup which won't start. The starter cranks well, I'm fairly certain the engine's getting gas, I've checked all the fuses, the battery's been tested and it's good, but I can't get it to turn over at all, much less start. It has sat for a few months. My best assessment for far is that it's not getting spark, but that could be wrong or if it's correct I don't know why.[/quote:ebc84d9b81]
Its getting fuel-start looking for spark at coil wire/s -No spark could mean distributor pick-up or if its a DIS check the cam/crank sensors. If the computer don't get the ignition signal it will not fire the coil.
Sep 17, 2007 at 6:34 AM
Suggested Repair
Check for spark at the coil wire. If there is no spark, test the distributor pickup; on a distributorless system, check the cam and crank sensors. Without an ignition signal, the computer will not fire the coil.
Conversation Summary
The owner of a 1982 Chevrolet 4.4L Caprice engine installed in a pickup says it cranks but will not start after sitting for several months. Fuel, fuses, and the battery appear okay, and lack of spark is suspected. The expert advises checking spark at the coil wire and, if absent, the distributor pickup or cam and crank sensors, because the computer will not fire the coil without an ignition signal.
