1991 Chevrolet Caprice No Start
KELBIZZLE
I have a 1991 Caprice classic with 75536 miles.
When I try to start the car the Engine will turn but will not start. I have never had this problem anytime starting it up. Now before this issue started I just drove the car home and starting taking the headlight switch (it arcs when they're are turned on) It did it a few times before removing it. Which is why I think I may have blew a fuse. I checked all the fuses on the drivers panel. They're all good. When I turn the key to the "on" position I don't hear the fuel pump..Should I? I think I may have blew the fuel pump fuse or the relay. What kind of jumper can I use to test the fuel pump?
Jun 16, 2007 at 5:57 AM
SERVICE WRITER
  • 9,123 POSTS
You should be able to hear the fuel pump. There is a by-pass test post that you can check the pump. It is located on the right side of the engine compartment.
Jun 16, 2007 at 12:39 PM
KELBIZZLE
I bypassed the relay and the pump did not run. So I replaced the pump. Upon replacing the pump. It didn't run when I turned the key. So I bypassed the relay once again. And the pump ran this time. After checking all the wires to the relay we found that we weren't getting voltage when turning the key. After taking a break and scratching my head. I checked all the panel fuses again. And also seen I had a blown ECM fuse. After all that it works now. The pump was apperently bad and I had blown a ECM fuse. Thanks alot.
Jun 18, 2007 at 12:46 PM
SERVICE WRITER
  • 9,123 POSTS
Those multiple problems can be stressful, especially after the work to change that pump. Glad to hear it all worked out, and thanks for finalizing the post.
Jun 18, 2007 at 1:01 PM
Suggested Repair
Confirm the fuel pump primes with the key on and test it at the bypass post on the right side of the engine compartment. If it does not run when bypassed, replace the pump. Also verify relay power with the key on and replace a blown ECM fuse, which can prevent the pump from receiving voltage.
Conversation Summary
A 1991 Chevrolet Caprice Classic cranked but would not start, and the fuel pump could not be heard priming after the headlight switch was removed. The expert advised listening for the pump and using the bypass test post on the right side of the engine compartment. Bypassing the relay showed the original pump was dead, so it was replaced. The new pump ran only when bypassed because the relay had no key-on voltage; a blown ECM fuse was then found. Replacing the pump and fuse restored operation.
