1987 Chevrolet Caprice Needs Jump
MSNIQUE
  • 6 POSTS
Hey there! I have a 1987 Caprice Classic that will only start if I jump it. It has a 445 Olds engine in it. Tested the battery, alternator and starter. All were fine. Once u jump it, it runs perfectly. Cut if off and it won't start back up without a jump. I also tuned the car up and replaced the alternator belt and a/c belt along with the battery cables. What could it possibly be??
Dec 24, 2006 at 6:31 AM
MATHIASO
  • 1,209 POSTS
what happened when you start the car? what do you hear? is the light on ??
Dec 24, 2006 at 7:00 AM
MSNIQUE
  • 6 POSTS
I have power...lights and everything come on. Cranks but won't turn over.
Dec 24, 2006 at 9:21 AM
IESUCK
[quote="MsNique"]I have power...lights and everything come on. Cranks but won't turn over.[/quote]
When it "Crank" do you hear the engine turning?
Dec 24, 2006 at 11:58 PM
MSNIQUE
  • 6 POSTS
[quote:8335f3534a="iesuck"][quote:8335f3534a="MsNique"]I have power...lights and everything come on. Cranks but won't turn over.[/quote:8335f3534a]
When it "Crank" do you hear the engine turning?[/quote:8335f3534a]
Yes.
Dec 26, 2006 at 3:03 AM
FFAS23
  • 25 POSTS
[quote:3b33831f1b="MsNique"]Hey there! I have a 1987 Caprice Classic that will only start if I jump it. It has a 445 Olds engine in it. Tested the battery, alternator and starter. All were fine. Once u jump it, it runs perfectly. Cut if off and it won't start back up without a jump. I also tuned the car up and replaced the alternator belt and a/c belt along with the battery cables. What could it possibly be??[/quote:3b33831f1b]
Did you or someone do a load test on your battery? Sounds to me like the battery may not have enough power in it to start your car. Maybe a bad cell in it and with the help of a jump from another car battery it will start. Next I would check the ground cable for a good ground. You may also have a bad solonoid or connection down at the starter. Sometimes the extra jolt from getting a jump will make it work. I still feel based on what you have said here that it may be your battery is at fought. Let us know how you make out.
fred
Feb 3, 2007 at 9:32 PM
MSNIQUE
  • 6 POSTS
Yes, it was the battery....thanks a bunch!
Apr 15, 2007 at 3:06 PM
Suggested Repair
Replace the weak battery after a proper load test. If the no-start returns, check the ground cable and starter solenoid connections.
Conversation Summary
A 1987 Chevrolet Caprice Classic with an Oldsmobile engine would only start when jumped, then ran normally but would not restart without another jump. Lights worked and the engine cranked. Battery, alternator, and starter tests were said to be fine, and belts and battery cables had been replaced. An expert suggested a battery load test for a weak cell, plus checks of the ground cable and starter solenoid. The owner later confirmed the battery was the cause.
