1992 Chevy Caprice not starting.
SANDSHARK23
  • 1992 CHEVROLET CAPRICE
  • V8
  • 135,000 MILES
I just changed the head gasket on my Chevy Caprice, now it isn't starting. I'm noticing that the fuel injectors aren't sending gas into the engine. I never had a problem with the injectors before changing the head gasket. I've already replaced the fuel pump and filter, so I'm wondering what could be the problem. Any help would be greatly appreciated?
CJ
Friday, November 30th, 2007 AT 5:24 PM
BLACKOP555
  • 10,371 POSTS
Make sure the injectors are plugged in properly in the harness. Next check for fuel pressure at the fuel rail and if that is good and the injectors are not putting out fuel check for injector pulse.
Friday, November 30th, 2007 AT 9:56 PM
