1977 Chevrolet Camaro Not Starting
77MARO
i have a 77 camaro. One day i was leaving Kroger and turned the key, it sounding like it was turning over but not starting. after a while it stopped cranking and started making a clicking sound until it finally just stop making noises at all. now i try to start it and nothing happens. Could it be the battery or the starter? Please help.
Sep 26, 2007 at 8:51 AM
Short answer is yes. This sounds exactly like a battery issue. I would suggest testing the battery and then replace it depending on the results.
Here are a few guides that will help with this type of testing and replacement of the battery:
https://www.2carpros.com/articles/symptoms-of-a-bad-car-battery
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Normal failures of batteries happen all of a sudden and happen with a clicking noise one day and then eventually they will be drained enough that they don't even turn the starter solenoid on to even click. You may hear a single click at this point.
Please run through all this material and let us know what you find. Thanks
Jul 21, 2021 at 12:55 PM
Suggested Repair
Test the battery with a load test and replace it if it fails. A sudden no-crank condition that progresses from cranking to clicking and then silence is typical of a drained or failed battery.
Conversation Summary
The owner of a 1977 Chevrolet Camaro said it sounded like it was turning over but would not start, then began clicking and eventually made no noise at all. The expert said this matches a battery failure and recommended testing the battery and replacing it if the test results call for it.
