1995 Chevrolet Camaro No Start After Days
FREAKSHOW
I have a 95 Camero 3.4 V6. The problem I am having is that if I let my car sit for more then a couple of days it will not start again unless I jump it. I have a new battery so it can't be that. Does anybody know what problems it could be??
Feb 5, 2007 at 2:44 AM
BUBBA_KOSKI
  • 129 POSTS
alternator, but get your battery fully charged before you start it on a new alternator.
Aug 17, 2019 at 10:08 AM
FFAS23
  • 25 POSTS
[quote:8196519826="freakshow"]I have a 95 Camero 3.4 V6. The problem I am having is that if I let my car sit for more then a couple of days it will not start again unless I jump it. I have a new battery so it can't be that. Does anybody know what problems it could be??[/quote:8196519826]
Why do you say that since you have a new battery that it couldn't be the problem?
If you need to jump the car that usually means your battery is drained and doesn't have enough juice in it to start your car. First things first. If I were you I would go out and purchase a battery charger of at least 10 amps. All car owners should have one. If you feel you can't be bothered or don't want to spend the money you will need to go all through the trouble of taking your battery out of the car and bringing it to someone else to give it a charge. Do that enough times and you will see the need to own a decent battery charger. Now if your car starts with a fully charged battery I would next check out that alternator or have someone check it to see if it is good on the car. A good alternator will put back in the electric taken out of the battery during starting keeping it charged while running the car. This is another cost factor if you need to have someone else test it if you don't have a Milton type battery testor around. Another tool worth having with that battery charger.
Another problem you may have here since you mentioned that after a couple of days your battery won't start the car. In this case I am willing to guess that you may have a electrical drain on your battery such as leaving an interior light on, glove box light on etc. Sometimes a short in the electrical system will cause this. If it isn't a interior light that was left on this may be a problem you may not be able to handle. Hope I was some help here.
Before I forget. Some people think that by just having your car jumped that your alternator will put a full charge back into your battery. This is not true. If anything at this point your are putting a strain on your alternator. Only a battery charger will be able to put a full charge back into your battery.
fred
Suggested Repair
Fully charge the battery with a charger, then test the alternator on the car. Also check for a parasitic drain such as a light left on or an electrical short. Jump-starting alone will not fully recharge the battery and can strain the alternator.
Conversation Summary
The owner of a 1995 Chevrolet Camaro 3.4 V6 says the car will not start after sitting more than a couple of days unless it is jump-started, despite a new battery. One reply points to the alternator but says the battery should be fully charged first. Another explains that a new battery can still be drained, recommends charging it with a charger before testing the alternator, and suggests checking for a parasitic electrical drain.
