1984 Chevrolet Camaro No-Start
ZZDOGMAN
I just got a 1984 camaro z28. It's got 110,000 miles on it and it has a 305 engine with auto trans. It was idling high so I adjusted the fast idle screw. The next day it wouldn't start. I have checked the ECM (good), the fuel pump, fuel is going into the carb, and I have spark to the plugs. It acts like it wants to start for awhile, but then nothing. Any help will be greatly appreciated. Thanks
May 19, 2007 at 8:16 PM
E40WATER12
  • 522 POSTS
Try and turn up the idle screw see what happens?. Might needt to adjust the fuel mixture screws, Also could have a carb plate gasket leak. or a leaking vaccum leak.
Jun 7, 2007 at 9:32 PM
KIRBSTER269
  • 14 POSTS
I would idle it back up and while car is running if running stick your head under the hood listen for a hissing sound that old of a car alot of vacuum hoses are dried out and leaking screws up the idle big time good luck
Jun 24, 2007 at 11:06 AM
Suggested Repair
Restore the idle screw setting, check the fuel mixture screws, and inspect for vacuum leaks and a leaking carburetor plate gasket.
Conversation Summary
The owner of a 1984 Chevrolet Camaro with a 305 adjusted the fast idle screw because it was idling high, and the next day it would not start. Fuel reaches the carburetor, spark is present, and the ECM was checked. Experts suggest raising the idle again, adjusting the mixture screws, and checking for vacuum leaks or a carburetor plate gasket leak.
