Car won't start
ZZDOGMAN
I just got a 1984 camaro z28. It's got 110,000 miles on it and it has a 305 engine with auto trans. It was idling high so I adjusted the fast idle screw. The next day it wouldn't start. I have checked the ECM (good), the fuel pump, fuel is going into the carb, and I have spark to the plugs. It acts like it wants to start for awhile, but then nothing. Any help will be greatly appreciated. Thanks
May 19, 2007 at 8:16 PM
E40WATER12
  • 522 POSTS
Try and turn up the idle screw see what happens?. Might needt to adjust the fuel mixture screws, Also could have a carb plate gasket leak. or a leaking vaccum leak.
Jun 7, 2007 at 9:32 PM
KIRBSTER269
  • 14 POSTS
I would idle it back up and while car is running if running stick your head under the hood listen for a hissing sound that old of a car alot of vacuum hoses are dried out and leaking screws up the idle big time good luck
Jun 24, 2007 at 11:06 AM
