1988 Chevrolet Camaro High Blower Out
1BRIAN26
  • 6 POSTS
I have a 1988 IROC-Z w/5.7 automatic. The high blower is not working. I have replaced the relay, resistor, and the switch in the dash! What am I missing? There is a red wire to the relay, it has 12V at all times, ignition on/off and all blower speeds, but as soon as I switch to high it goes to 0V
Aug 7, 2007 at 9:31 AM
SERVICE WRITER
  • 9,123 POSTS
I believe that just leaves the blower as the problem.
Aug 7, 2007 at 10:56 AM
SERVICE WRITER
  • 9,123 POSTS
Looking at the wiring diagram, I see ther is a 4 amp in-line fuse on the red wire, did you check it?
Aug 8, 2007 at 3:45 AM
SERVICE WRITER
  • 9,123 POSTS
Brian, Keep the posts on the forum Please. I may have had the wrong diagram before, but this is what I see:
https://images.2carpros.com/forum/automotive_pictures/30961_blower_dia_1.jpg
Based on what you replaced, If the fuse is good, check the continuity of the PPL wire and the ORG wire. This should be the fuse:
https://images.2carpros.com/forum/automotive_pictures/30961_blsw_1.jpg
Aug 12, 2007 at 1:12 PM
1BRIAN26
  • 6 POSTS
I spoke with a friend who said he felt that the fusible link to the blower is going bad and that it can handle the lower speeds, but when high is on it cuts out. That is why the hot at all times goes to 0 volts on high.
Aug 14, 2007 at 1:11 PM
Suggested Repair
Check the 4-amp inline fuse on the red wire to the blower relay. If it is good, check continuity of the purple and orange wires. A weak fusible link that opens under high-speed load is also possible; if the fuse and wiring check out, test the blower motor.
Conversation Summary
The owner of a 1988 Chevrolet Camaro IROC-Z says high blower speed does not work after replacing the relay, resistor, and dash switch. The red wire at the relay has 12 volts until high is selected, then voltage drops to zero. The expert advised checking the 4-amp inline fuse on the red wire and, if good, continuity of the purple and orange wires. A friend suggested a failing fusible link that cannot carry the high-speed load.
