1999 Chevrolet Camaro AIR Pump Location
TMILLSD
P1416 Secondary Air System, P0410,P0412,P0418,P0137,P0157
Diagnosed fuse for AIR PUMP BLOWN. AIR PUMP INTERNALLY LOCKED UP. Needs Air Pump and Fuse.
This is what the mechnanic told me. and would cost over $500.00 to fix. I would like to do this myself and would like to know where the Air Pump is located?
Mar 10, 2007 at 1:51 PM
2CARPRO JACK
  • 11,533 POSTS
I believe it is mounted on the lower drivers side front of the engine. The secondary air codes are probably due to blown "gulp" valves, they keep exhaust from being pushed back into the air pump, which is possibly why yours locked up.The valves are on the lines that come out of the exhaust manifolds.
Mar 11, 2007 at 12:19 AM
Suggested Repair
The secondary air pump is believed to be on the lower driver's side front of the engine. Replace the locked pump and blown fuse, and inspect the gulp valves on the lines from the exhaust manifolds, since failed valves can push exhaust back and lock the pump.
Conversation Summary
A 1999 Chevrolet Camaro 5.7 has secondary air and oxygen-sensor codes. A mechanic found a blown air-pump fuse and an internally locked air pump, estimating over $500. The owner wants the pump location. The expert says it is likely on the lower driver's side front of the engine and that failed gulp valves on the exhaust-manifold lines may have caused the pump to lock.
