Thanks!
1986 Chevrolet Camaro After 5 Years
Thanks!
After checking and replacing the fluids and looking at the plugs to make sure they are not oil fouled or in bad shape it should start just fine. Be prepared for some smoke from the tailpipe as it will more than likely burn and deposits that have been sitting in the system. Watch the engine compartment for unusual burning and the temperature guage for unsual heating issues.
Good luck!
Thank you so much for the good advice. I'll post a message here at the board once I get it started to let you know how things went!
D
Dawn
Suggested Repair
Before adding fuel or cranking, change the oil and check coolant, spark plugs, and plug wires. Remove the spark plugs and add lubricant to each cylinder in case the rings have stuck after long storage, then reinstall the plugs. After fluids and plugs are addressed, add fresh fuel and start the car while watching for tailpipe smoke, unusual burning in the engine bay, and abnormal temperature readings.
Conversation Summary
The owner of a 1986 Chevrolet Camaro that had sat for about five years with an empty fuel tank asked whether fresh gas and a new battery were enough to start it safely. Experts advised changing the oil and checking coolant, plugs, and wires before starting, and also removing the plugs to lubricate the cylinders because the rings may have seized. The owner planned to have the fluids changed and the cylinder lubrication done before attempting to start the car.
