1992 Chevrolet Camaro A/C Compressor
CHEVROLET
CORAYBELL
Hi I'm currently doing an engine swap on a 1992 camaro. The camaro has a 5.0 305 for an engine. The engine I am putting in is a 1994 LT1 from an Impala. My question is can I purchase a 1994 corvette a/c compressor and use it on my a/c system? The reasoning behind this is that the 1994 Impala a/c compressor hits my frame. I do not wish to notch my frame or buy a cheap looking bracket for $500. So I was thinking of getting a used bracket and new a/c compressor for a 1994 corvette might fix the problem since this item is located on the top drivers side. Once again my question will the corvette a/c compressor work on my a/c system?
Jan 24, 2007 at 12:12 PM
INDYUKE
  • 416 POSTS
I don't see why not. 1) make sure that the refrigerant line fittings are the same so it will screw right into the compressor, 2) make sure the compressor you are planning on using uses the same type of refrigerant as the rest of the A/C system you are planning on using, and 3) make sure the wiring harness will plug into the compressor or can be adapted.
I hope this helps. Maybe someone else out there has some more suggestions on what to watch out for.
Jan 24, 2007 at 1:27 PM
Suggested Repair
A 1994 Corvette A/C compressor may work if its refrigerant-line fittings match the Camaro system, it uses the same refrigerant, and the wiring harness plugs in or can be adapted.
Conversation Summary
The owner of a 1992 Camaro is swapping a 1994 Impala LT1 for the original 5.0 and asks whether a 1994 Corvette A/C compressor can be used because the Impala compressor hits the frame. The expert says it should work if the line fittings, refrigerant type, and wiring are compatible.
