Choke
CHEVROLET
FYRPUPPY
My choke light stays on all the time and the truck diesels when you shut it off. 1983 silverado 4x4 just barely 100 miles on a jasper replacment engine. i have replaced the choke thermostat and this did not change anything. I am being given the runaround by the guys that just repalced the motor so I am trying to handle it myself.
Jan 19, 2007 at 12:10 AM
[quote:cd6f4002fb="fyrpuppy"]My choke light stays on all the time and the truck diesels when you shut it off. 1983 silverado 4x4 just barely 100 miles on a jasper replacment engine. i have replaced the choke thermostat and this did not change anything. I am being given the runaround by the guys that just repalced the motor so I am trying to handle it myself.[/quote:cd6f4002fb]
You need to adjust your fast idle cam-the reason you're dieseling is because the throttle plate is not fully closed creating your Run-on. Some thing is holding the plate open investigate thoroughly. and also recheck the ignition timing.
Jan 19, 2007 at 5:00 AM
FYRPUPPY
It didn't start doing this till the choke light came on and now it will not go off. I checked the voltage going to the choke thermostat( I was told it probably didn't have any power. It has DC voltage with the switch on and with the truck running.
Jan 19, 2007 at 10:23 AM
