1996 Chevrolet Camaro Heater Blows Cold
MTNBKR88
Chevy Camaro 1996 101,000 miles 3.8L; This past week the heater started blowing only cold air. The temperature guage behaves like normal. Warms up to around 190. Gets a little warmer during stop and go traffic, then quickly back to normal once moving along again, so I think the thermostat is working ok. I checked around the heater core and I can definitely tell changing the temperature setting opens and closes the vent door and the fan is blowing. The hoses going to and from the heater core are both cold when checked near the water pump. The radiator is full. I replaced the water pump around 60K miles (five years ago) and noticed the blades were pretty worn. Did the blades wear down again? Is there a way to check the blades without emptying the cooling system? What's wrong? Thanks.
Apr 17, 2007 at 5:15 PM
EUGENE123
  • 273 POSTS
it is possible that the blades wore down again and no the only way to check the blades is take the water pump off and look at them thats where i would start if everything else has checked out
Mar 17, 2009 at 6:06 AM
Suggested Repair
If the heater controls and coolant level check out, remove the water pump and inspect the impeller blades for wear.
Conversation Summary
A 1996 Chevrolet Camaro with a 3.8L engine blows only cold air from the heater, although the temperature gauge warms normally to about 190 degrees. The blend door and fan work, the radiator is full, and both heater hoses are cold near the water pump. The owner previously found worn water-pump blades at 60,000 miles. The expert says the blades may have worn again and that the pump must be removed to inspect them, which is where to start.
