Electrical problem
1998 Chevy Camaro 6 cyl Wheel Drive Type unknown Automatic 2000 miles
someone riped out the alarm system wires and the car wont start now. How do I fix it?
Thursday, February 21st, 2008 AT 8:40 AM
DAN P
MEMBER
Is this a aftermarket alarm? Look at the bottom of str column, if wires are cut, look for a 10 gau yellow wire comming from elec ign switch, this is the wire that they put the starter interlock on, splice the two yellow wires back together should crank.
