Here's The Thing. I Got 1998 Chevy Camaro 3.8L V6 5 Speed. The Car Was Running Great, All Maintenance Was Done On It On Time, For A 130K Miles Engine It Was Running Great. Untll One Day, When I Got To The Car After Work And It Just Won't Start. It Wasn't Turning The Engine At All. Next Day It Was Towed To The Shop, They Replaced Starter And One Relay And The Car Was Running Again. Few Weeks Later, The Same Thing Happened, Again After Work. Since It Was Weekend I Left The Car On The Parking Lot Until Monday. When I Came To Pick It Up And Get It Towed Again, It Still Won't Start, But The Engine Was Turning. There Was No Ignition, But I Could Hear The Fuel Pump Working. The Car Is Now 3 Weeks In The Shop, And Guys Over There Can't Figure It Out What's Wrong With It. They Already Changed Ignition Module, Checked All Wiring And Still Not Starting. They Said They Had It Up And Running Once, They Drove It Around And Then Came Back. Tried To Start It Again After 10 Minutes And Again It Won't Start. After That They Checked The Computer Again And Found Out, That ECU Is Not Showing That The Engine Is Turning. Thay Assumed That Since ECU Is Not Showing Engine Turning, It's Not Releasing Ignition To The Module. They Changed The Sensor Next To Fly Wheel On The Engine, But It Won't Help. Car Is Still Not Getting Spark (checked With In-line Sensor), Neither It Has No 'pulse'. Today I Went To Check On The Car, And They Told Me That They Can't Find Anything, So I Will Have To Tow The Car To Chevy Dealership And Probably Get New ECU Or Have Mine Reprogrammed. Also My Bill For Not Fixing The Car Is 600$ Now, And Again Dealership Will Probably Charge Me About 600$ Just To Reprogram The ECU. I'm Still Wondering What Else Could It Be. If I'll Have To Take The Car To Dealership, I'd Rather Tow It To Junk Yard And Get Rid Of It, Hopefully Getting For It Enough To Pay The Bill. Any Ideas?
SPONSORED LINKS
Thursday, May 8th, 2008 AT 7:24 PM
