I was having lots of problems with a misfire on Cyl3 and have went through several Coil packs on just that Cyl I was told that my problem was the control module below the coil packs. So I bought all new coil packs and a new module I sanded the aluminum plate that the old one was on and applied the grease as directed I did have a problems with the bolts that hold the coil packs down so these have all been replaced with metric screws and nuts. I secured the coil packs to the module to the aluminum bracket and re attached the bracket back to the motor I reattaced the lead to the moduel and snugly scewed it together making full contact. The car will not start now Im lost as to why the firing oder is correct verified from 3 sources front coil back to back coil pack
is 6, 3, 2, 5, 4, 1
I am truely lost, Nothing else on the car has been touched. I apper to have good spark also. Also pulled moduel off and had it checked at the parts house it checks out fine all green.
Thanks for any imput
SPONSORED LINKS
Sunday, June 8th, 2008 AT 10:42 PM
