1991 Chevy Camaro Will not start after shutting off
TSTREBE
  • 1991 CHEVROLET CAMARO
Electrical problem
1991 Chevy Camaro V8 Two Wheel Drive Automatic
91 Z28 5.0 TPI
Car starts fine runs good till you shut it off then it will not start for about 3 hours. {Enigine turns over.)Then it will start and run fine till you turn it off again? Note: engine will try to start with starter fluid. New dis, new fuel filter, new fuel pump relay, ?
Thursday, June 17th, 2010 AT 2:32 PM
Check the fuel pressure if its within specs if so make sure it holds that pressure 10mins or so if not check the injectors and fuel pressure regulator and fuel pump check valve if its leaking
Saturday, August 17th, 2019 AT 5:01 PM
