1991 Chevy Camaro Clutch to Floor
NASCAR20
I drove my car to town one got back in it it would not start. Everything else works fine but it would not start, click, or do anything. I need help getting my car back on the road. I have changed the nutural switch and it did not help any. I can not figure it out nor can my brother inlaw that is a mechanic. HELP!!!!! My car has 160,00 miles with a 5.0 engine.
Jan 29, 2007 at 7:47 AM
  • 75,988 POSTS
Try clean and tight connections on the battery and starter then go find the fusible links.Okay there start at the ignition switch
BTW when key is in On position -do you see any idiot lites on the panel.
Aug 17, 2019 at 10:03 AM
ERVINKING5
clutch goes all the way to the floor,and wont shift,but will start
Mar 2, 2021 at 3:04 AM (Merged)
  • 31,937 POSTS
Hi there,
If no pedal pressure, check the clutch fluid level, if low you will have a leak at the master cyl or the slave cylinder, you may be able to get some pedal back by adding fluid , and cracking the bleeder with your foot on the clutch, close bleeder lift pedal and repeat, checking that fluid is not to low after each bleed, this should give you enough clutch to get to a mechanic to get it check over.
mark (mhpautos)
Suggested Repair
If the clutch pedal has no pressure, check the clutch fluid level. A low level indicates a leak at the master or slave cylinder. Add fluid and bleed the system by cracking the bleeder with the pedal down, closing it, lifting the pedal, and repeating while keeping the fluid topped up. This may restore enough clutch operation to reach a mechanic for inspection.
Conversation Summary
The owner of a 1991 Chevrolet Camaro RS with a 5.0 engine first reported a no-crank, no-start condition after a short trip and said replacing the neutral safety switch did not help. An expert suggested checking battery and starter connections, fusible links, and the ignition switch, and asked whether warning lights appeared with the key on. The owner then reported that the clutch pedal goes to the floor and the car will not shift, although it will start. A second expert advised checking the clutch fluid and bleeding a leaking master or slave cylinder enough to drive it to a shop.
