I am replacing the sensors because as I stated, when I took it to the machanic and he plugged it into the computer, those are the things he said I needed. I wouldn't have touched them if he didn't say I needed to replace them. Ther was plenty of gas getting through when we tried to start it, you could smell it. Wasn't having any other problems with spark or compression. Any other thoughts?
Well. We got it running. Changed a few connectors that idn't look too goo, put a charge n the battery and it did ge started. After doing everything that the mechanic asid to change. It has no power, less than before, and after about 10 miutes when it get warm, it dies. If it doesn't de, when you shut it off it won't even turn over until it is cool. Any suggestions?
SPONSORED LINKS
Saturday, August 17th, 2019 AT 5:01 PM
