OK I have a 91 camaro that after you drive for a while it wont start for 2 hours?Help
Wednesday, October 21st, 2009 AT 9:09 AM
JDL
MECHANIC
Welcome, need more info, When it refuses to start do you have spark at the plugs? Any codes? When was the last tune-up?
SPONSORED LINKS
Saturday, August 17th, 2019 AT 5:02 PM
BCPBALLER64
MEMBER
No codes it says that the coolant light is on says it is too hot maybe bees new computer? You can start it turn it off and back on but if the engine gets olabove 200 degrees (normal temp) then you have to wait till the engine gets to room temp to start again
GOTAY5
MEMBER
ENGINE IS 305 o 350?
MY EMAIL gotay.5@hotmail.com
My Phone Num (845) 986-1863
Up,
Up State New York .......
MARVIN MEADE
MEMBER
1 POST
Chexk pickup coil in disturblar pull dist. Cap check pickup coil plug were plugs into module see if plastic brunt cracking simple ohm test.
