1996 Chevrolet Blazer Key Won't Turn
MICHIE45
1996 Cheve Blazer 4WD
143,120
6Cyl 4.3LTRE
The Engine key will not move.
After trying the usual of turning the wheel slightly it still will not move. In fact my husband snaped the steering wheel lock by doing this that it no longer locks.
Which is no big deal right now, because we have bigger problems.
Do we need a new ignition switch or could it be something else? He checked all the fuses. He hot wired the truck & it did start that way.
But they key will not turn. It will not go into gear or anything.
Is it the ignition or the steering column?
PLEASE PLEASE HELP!!!!
Jun 9, 2007 at 5:06 PM
E40WATER12
  • 522 POSTS
Sounds to be youre trucks igintion key cyl needs replacing, The tumblers in the key are jammed.
Jun 9, 2007 at 6:49 PM
MICHIE45
It thatthe ignition switch or something else?
I have to bethe oneto call around to see how muchthey are.
Since he works nights.
Thank You
Jun 10, 2007 at 3:38 AM
Suggested Repair
Replace the ignition key cylinder. Jammed tumblers in the cylinder are likely preventing the key from turning.
Conversation Summary
A 1996 Chevrolet Blazer key will not turn, even after slightly moving the steering wheel. The steering lock was broken while trying to free it, fuses were checked, and the truck started when hot-wired, but the key still will not turn or allow shifting. The expert said the ignition key cylinder needs replacement because the key tumblers are jammed.
