My 2003 Blazer just started having this problem. I cannot get the key out. Have had to start vehicle every few hours so the battery does not die. Have tried disconnecting battery at night. Then I have serious problem starting vehicle. Takes 30-45 minutes for the Blazer to hold it's own idle. While locksmith "fixed" key issue the battery was disconnected only to have the same problem starting it back up. Had a locksmith change the key lock and got new keys. Worked great until I went across town then key is stuck in the ignition again. I could really use advice on what to have looked at. By the way I had a faulty air sensor replaced. Problem started just b-4 . Had plugs checked and they are clean.
Jan 5, 2007 at 2:36 PM
